[postgis-users] points to lines
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Jul 20 07:15:02 PDT 2009
ahmed at elegantdesigns.ca wrote:
> Hello list,
> I have a point table with the following format:
> id node_1 node_2 weight
> 1 1 2 5.4
> 2 1 3 2
> 3 2 4 6
> 4 4 4 1
> the table is about 2,000 rows long.
> i was wondering how can i convert this table into a line layer such that:
> * line should be created between node_1 and node_2
> * a weight field/attribute be added corresponding to the link
select AddGeometryColumn('public', 'lines', 'the_geom', 4326,
'LINESTRING', 2);
update lines set the_geom=setsrid(st_makeline(
(select the_geom from points where node_id=node1),
(select the_geom from points where node_id=node2),
4326);
Something like the above should work.
-Steve
