[postgis-users] Issue with spatial query (PostGIS, ST_DWithin, SRID, transform)
    Mulone
    andrea.ballatore at ucd.ie
    Thu Jul 23 12:02:55 PDT 2009
Hi Pedro,
Thanks for your reply.
I've tried to re-project everything with
SELECT osm_id FROM planet_osm_polygon WHERE
ST_DWithin(ST_transform(way,2163),ST_transform(GeomFromText('POINT(53.30124
-6.21804 0)', 4326),2163), 100);
But it doesn't return anything.
That's my scenario: there is just one polygon within 100m, and I'm actually
able to get that object if I enter 84.16 as a distance. Is there a logical
explanation to this? With such a huge distance I would expect postigs to
return everything.
Pedro Doria Meunier wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Mulone,
> Openstreetmap uses a Mercator projection.
> When you specify '100' you're actually saying 'give me everything
> within 100 *degrees*'
> You should reproject your data to the desired/applicable projection by
> means of transform();
> HTH,
> Pedro Doria Meunier
> GSM: +351 96 17 20 188
> Skype: pdoriam
> Mulone wrote:
>> [apologies for cross posting]
>> Hello,
>> I'm running some queries on a PostGIS db containing OSM data loaded with
>> osm2pgsql.
>> I want to get the geometries within a certain distance from a point. I've
>> written this query:
>> SELECT osm_id FROM planet_osm_point WHERE
>> ST_DWithin(way,geomfromtext('POINT(53.30124 -6.21804 0)', 4326), 100);
>> where 100 is meant to be 100 meters. This query returns all the objects
>> in
>> the table, and running it with different distances I found a sort of
>> threshold around 84.16, where I start getting less objects.
>> I thought it was an issue related to the system reference, so I tried
>> with
>> this conversion:
>> ST_DWithin(transform(way,2163),transform(geomfromtext('POINT(53.30124
>> -6.21804 0)', 4326),2163), 5740000);
>> The threshold in this case seems to be about 5740000, which is
> obviously not
>> meters.
>> How can I figure out the units DWithin is working in?
>> Besides, I doubt this is the best way to do what I want, any better
>> ideas?
>> Thanks in advance!
>> Mulone
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.7 (GNU/Linux)
> Comment: Using GnuPG with Fedora - http://enigmail.mozdev.org
> iD8DBQFKaK5G2FH5GXCfxAsRAiNvAJwND0pmRWNaODnJ0foW9uraaS1YnACfbdIX
> +de0ZbKmALUpjlFbzbO/rnk=
> =eWY7
> -----END PGP SIGNATURE-----
> postgis-users mailing list
View this message in context: http://www.nabble.com/Issue-with-spatial-query-%28PostGIS%2C-ST_DWithin%2C-SRID%2C-transform%29-tp24631779p24632149.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
