[postgis-users] Two geometries same column
Bob Pawley rjpawley at shaw.ca
Sat Jul 25 11:30:54 PDT 2009
Hi
I ahve two geometries say A and B in the same column.
I want to make a line between geometry A and geometry B.
How can I write the expression so that Postgresql recognizes that A and B are in separate rows?
I have tried the following which produces a null return.
update a --p_id.image
  set one = --the_geom =
 (select st_makeline(st_makepoint(st_x(st_centroid(p_id.image.the_geom)), st_y(st_centroid(p_id.image.the_geom))),
  from p_id.image
  where (p_id.image.fluid_id =  '1513'
  and p_id.image.description = 'A')
  and (p_id.image.fluid_id = '1513'
  and p_id.image.description = 'B'))
Bob
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090725/c7b5dd18/attachment.html>
