[postgis-users] postgis1.4.0 installation errors on pgsql8.4
Ben Madin ben at remoteinformation.com.au
Mon Jul 27 16:59:58 PDT 2009
Ravi,
You need to at least send some error messages!
The failure of one part of the script means everything else is
failing, so send the output including at least what was working and
the first few error messages and I think you can probably expect more
help.
cheers
Ben
On 28/07/2009, at 5:53 AM, Ravi wrote:
> Hi,
> trying latest pgsql8.4 and postgis1.4.0 on Win-XP
> pgsql8.4 was installed OK.
> in the readme.txt of postgis (zip) downloaded, using the steps, the
> following errors occur (from dos prompt screen)
> CAPS are my prompts below.
> --Creating a template postgis database or new postgis database  --
> 1) Copy the contents of this folder into C:\Program Files\PostgreSQL
> \8.4 or where you have installed
> DONE OK (Just copied the folder postgis-pg84-binaries-1.4.0 in C:
> \Program Files\PostgreSQL\8.4)
> 2) "C:\Program Files\PostgreSQL\8.4\bin\psql" -p 5432 -U postgres -c
> "CREATE DATABASE template_postgis14"
> DONE OK
> 3) "C:\Program Files\PostgreSQL\8.4\bin\psql" -p 5432 -U postgres -d
> template_postgis14 -c "CREATE LANGUAGE plpgsql"
> SYSTEM SAYS IT ALREADY EXISTS
> 4) "C:\Program Files\PostgreSQL\8.4\bin\psql" -p 5432 -U postgres -d
> template_postgis14 -f "C:\Program Files\PostgreSQL\8.4\share\contrib
> \postgis\postgis.sql"
> THIS ABORTED AFTER MANY LONG Messages
> STEPS 5,6,7 to be done
> Ravi Kumar
>      See the Web's breaking stories, chosen by people like you.
> Check out Yahoo! Buzz. http://in.buzz.yahoo.com/
> postgis-users mailing list
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
							Out here, it pays to know...
