[postgis-users] [off-topic] How to init postgres databases onwindows F: drive
Paragon Corporation
lr at pcorp.us
Tue Jul 28 14:39:35 PDT 2009
Steve,
Actually that setting I believe was an option (I think the second step on
the enterprise db installer).
There are 3 ways that come to mind
1) Way one I haven't tried but should work
a) Stop the postgresql service
B) Copy the data folder you already initialized to the F drive nd set
permissions to allow postgres account full rights
C) change the postgresql.conf in the data folder
D) delete the service with a
Sc delete "name of postgresql service here"
E) Reinstall the service with
Using
pg_ctl register -N ....
Basically what is described here
http://trac.osgeo.org/postgis/wiki/UsersWikiWinCompileInitdb
Way 2) assuming you have no data. You could just uninstall and reinstall.
Way 3) Create a new cluster with initdb -- also in above link (this only if
you have no data)
Leo
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
Woodbridge
Sent: Tuesday, July 28, 2009 5:20 PM
To: PostGIS Users Discussion
Subject: [postgis-users] [off-topic] How to init postgres databases
onwindows F: drive
Hi all,
Sorry for a little bit off topic post, but I'm trying to setup a new
postgresql/postgis install on a Windows box and I need the data files to be
on the f: drive. I'm using postgres 8.3.7 and postgis 1.4
Can anyone tell me how to do this?
Unfortunately out of the box it installed everything on the C: drive and I
do not remember seeing an option on where to be the data files?
Thanks,
-Steve W
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
