[postgis-users] Returning multiple fields from a plpgsql function
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Jul 29 11:19:10 PDT 2009
This is another slightly off topic, but maybe generally helpful inquiry.
I have a plpgsql function the does some spatial queries and returns
results using a type like:
CREATE TYPE my_result AS
(attr1 text,
attr2 text,
attr3 text,
distance float,
linkid int);
in the function:
DECLARE
ret my_result;
then set the values of the fields like:
ret.attr1 := attr1;
and return the results like:
return ret;
later I do:
select my_function(x,y);
and get a result that looks like:
("attr1","attr2","attr3",102.2,1234567)
which all looks fine and dandy, except that I can not seem to access the
individual fields. So for example if I want the value of my_result.attr1
how would I get that? Is there a better way to do this?
Thanks,
-Steve
