[postgis-users] liblwgeom is missing after postgis 1.4 build
Suhr, Ralf Ralf.Suhr at itc-halle.de
Thu Jul 30 08:16:49 PDT 2009
Hi Otto,
the libraryname has changed from liblwgeom.so to postgis-1.4.so.
Gr Ralf
-----Ursprüngliche Nachricht-----
Von: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von Otto Dassau
Gesendet: Donnerstag, 30. Juli 2009 17:04
An: PostGIS Users Discussion
Betreff: [postgis-users] liblwgeom is missing after postgis 1.4 build
I compiled postgis 1.4.0 on opensuse 11.0, but liblwgeom.so* is not built. The log says:
make -C liblwgeom
make[1]: Entering directory `/usr/src/packages/BUILD/postgis-1.4.0/liblwgeom'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/usr/src/packages/BUILD/postgis-1.4.0/liblwgeom'
I built postgis 1.3.5 with liblwgeom succesfully on the same machine with the same configuration. Are there any new, special dependencies I need to add to get it build?
-------------- Compiler Info -------------
 C compiler: gcc -march=i586 -mtune=i686 -fmessage-length=0 -O2 -Wall -D_FORTIFY_SOURCE=2 -fstack-protector -funwind-tables -fasynchronous-unwind-tables
C++ compiler: g++ -march=i586 -mtune=i686 -fmessage-length=0 -O2 -Wall
-------------- Dependencies --------------
  GEOS config:          /usr/bin/geos-config
  GEOS version:         3.1
  PostgreSQL config:    /usr/bin/pg_config
  PostgreSQL version:   8.3
  PROJ4 version:        46
  PostGIS debug level:  0
thanks in advance
 Otto
postgis-users mailing list postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
