[postgis-users] ST_Dump-like function for simple (non-multi) geometries ?
David William Bitner david.bitner at gmail.com
Fri Jul 31 11:36:29 PDT 2009
I would add that, especially with plpgsql or sql wrappers to PostGIS that
others might find useful, there is the user contributed plpgsql section on
the wiki: http://trac.osgeo.org/postgis/wiki/UsersWikiMain
On Fri, Jul 31, 2009 at 1:20 PM, Kevin Neufeld <kneufeld at refractions.net>wrote:
> Unfortunately, I think your solution is overly simplistic.  I think the
> community is after something that mimics the ST_Dump and ST_DumpRings
> functionality.
> ie.
> SELECT (ST_Dump('MULTILINESTRING((0 0, 1 1),(2 2, 3 3))'::geometry)).*;
>  path |                                        geom
>  {1}  |
> 01020000000200000000000000000000000000000000000000000000000000F03F000000000000F03F
>  {2}  |
> 0102000000020000000000000000000040000000000000004000000000000008400000000000000840
> (2 rows)
> In order to extract all the points from every geometry in a table we would
> need to be able to have this example query work that also returns a SETOF
> geometry_dump:
> SELECT (ST_DumpPoints(the_geom)).*
> FROM my_spatial_table;
> The path portion of the geometry_dump datatype is important because users
> know the index of POINT in the geometry. It'll be possible then, for
> example, to extract all but the endpoints.  Additionally, users could group
> the points back together to rebuild the original geometry from whence they
> came.
> Also, your function would need to be a lot more robust (ie. ideally, able
> to accept all geometry types, POINT, LINESTRING, MULTIPOLYGON,
> GEOMETRYCOLLECTION, etc).
> I agree, the st_dump code does indeed look a little overwhelming.  I don't
> think we're tied to having the function written in C (there are many plpgsql
> functions in PostGIS).  If you think you can come up with something that
> meets the desired specifications, please, by all means, feel free to propose
> something to the postgis-devel list.  We'd love the help!
> Cheers,
> Kevin
> Maxime van Noppen wrote:
>> I was looking to PostGIS source code to see how hard it is to implement
>> and if I could be of any help but the st_dump function implementation is
>> quite complicated (at least for somebody exterior to the project).
>> Is there any reason not to provide the function as an plpgsql
>> function ? Would a C implementation run really faster ?
>> The SQL code seems quite simple, I currently use something like :
>> CREATE FUNCTION dump_line(l geometry) RETURNS SETOF geometry AS $$
>> BEGIN
>>  FOR i IN 1..ST_NumPoints(l) LOOP
>>    RETURN NEXT ST_PointN(l, i);
>>  END LOOP;
>> END
>> $$ LANGUAGE plpgsql;
>>  _______________________________________________
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090731/f54a953d/attachment.html>
