[postgis-users] How to create a spatial index for a grid in a subquery?
Tyler Erickson
tyler.erickson at mtu.edu
Wed Jul 15 14:59:50 PDT 2009
I am trying to create a query that intersects polygons with a regular grid.
I would like to create the grid on-the-fly, so that any projection, extent,
and spacing could be used.
The query I've come up with is based off of example code found in the
PostGIS in Action book (Listing 5.3), which uses generate_series() and
ST_MakeBox2d() to create a grid in a subquery. While this works for fine
for coarse grids, this approach quickly slows down for fine grids,
presumably because the grid created in the subquery does not have spatial
index.
What would be a good approach for creating and intersecting with a fine
grid? Should I create the grid in a temp table, create a spatial index,
then intersect it with polygons? Or is there a way to create a spatial
index within the a subquery?
Below are examples of my current query, and the example query from PostGIS
in Action.
- Tyler
-- Intersect polygon with grid (151 x 301 = 45451 cells; 14s execution time)
SELECT
CAST(x AS text) || ' ' || CAST(y As text) As grid_xy,
ST_AsText(ST_Intersection(g1.geom1, g2.geom2)) As intersect_geom
FROM
SELECT
ST_GeomFromText('POLYGON((2 4.5,3 2.6,3 1.8,2 0,-1.5 2.2,0.056
3.222,-1.5 4.2,2 6.5,2 4.5))') As geom1
) As g1
INNER JOIN
SELECT
g0.x, g0.y,
CAST(ST_MakeBox2d(ST_Point(-1.5 + g0.x, 0 + g0.y), ST_Point(-1.5 +
g0.x + 2, 0 + g0.y + 2)) As geometry) As geom2
FROM
SELECT
x_raw/100.0 as x,
y_raw/100.0 as y
FROM generate_series(0,300,2) As x_raw
CROSS JOIN generate_series(0,600,2) As y_raw
) as g0
) As g2
ON ST_Intersects(g1.geom1,g2.geom2);
-- Intersect polygon with grid (2 x 4 = 8 cells; 12ms execution time)
-- Source: PostGIS in Action, Listing 5.2(3)
SELECT
FROM
(SELECT
) As g1
INNER JOIN
(SELECT
x, y, CAST(ST_MakeBox2d(ST_Point(-1.5 + x, 0 + y),
ST_Point(-1.5 + x + 2, 0 + y + 2)) As geometry) As geom2
FROM generate_series(0,3,2) As x CROSS JOIN generate_series(0,6,2) As y
) As g2
View this message in context: http://old.nabble.com/How-to-create-a-spatial-index-for-a-grid-in-a-subquery--tp28248823p28248823.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
