[postgis-users] ESRI GDB format into PostGIS
Simon Greener
simon at spatialdbadvisor.com
Tue Jun 2 04:23:08 PDT 2009
Alan,
> Well, maybe not that much, but a bit. The reason I'm watching is because I'm
> hanging out to be able to afford an FME licence.
Have you tried that doyen of the open spatial world: Talend's Spatial Data Integrator?
>> Shall we start a survey on what people in this forum think?
> I think that would be a great idea.
Well folks, there's the question:
How many (Enterprise/Personal) GeoDatabases are fully designed, specified and implemented such that
they can use the Code Generation Wizard to generate code that implements “behaviours” within the ArcGIS technology?
> I've fully designed and specified four 'enterprise' spatial databases and a
> dozen or so large, complex 'application' ones. None have been implemented as
> designed because the spatial experts (yes 'ESRIlites') all end up saying
> "ArcMap will cark it." (BTW: I still believe that there is nothing to stop
> you implementing a multi-geometry column table in a geodatabase; you just
> have to manage it yourself because the ESRI application infrastructure
> won't. Which, I think is your point. I say 'believe' because I haven't been
> able to get anyone imaginative enough to prove its scalability in a 'real'
> environment.)
There isn't anything stopping you if you are prepared to do a bit of "behind the scenes" manipulation of ArcSDE. During the beta for SDE 2.0 (the first ESRI Inc produced) I showed how to have two spatial columns per table. Can be done.
> People like the model simple because it makes the application of it simple.
> Lots more work, but simple. ("Waddaya mean 'I should write a query for my
> map layer'? Make me a new table!") Gee - I really am getting crankier as I
> get older!
You and I ought to take this off line as I have comments on this that might offend!
> So, back to the issue: I spent most of the 90's working on Data Interchange
> and ended up completely disillusioned. One interchange format will never
> cover all the bases. The dream now is for an Open Spatial ETL suite.
> (GDAL-OGR-FDO with muscle.)
Again, see Talend.
I've been hoping for Spatial SQL JDBC/ODBC/ADO etc etc drivers for years and years and years. Guess they might just never arise.
> None of this helps Ben with his problem but I do think it points to an
> answer for your question " why do we waste our time looking over our
> shoulders?" - Because they're the elephant in the room.
Even if this elephant wanted to be gentle (as their maketing says) they simply can't: not enough brain cells
to drive the physical body. And I won't be in a hurry to be in the same room as them.
> Cheers, and thanks for your insights on the workspace.xml
I have plenty of samples and some XSLT-style processing if you are interested. But contact me off-line.
S
SpatialDB Advice and Design, Solutions Architecture and Programming,
Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME, Radius Topology and Studio Specialist.
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
Website: www.spatialdbadvisor.com
Email: simon at spatialdbadvisor.com
Voice: +61 362 396397
Mobile: +61 418 396391
Skype: sggreener
Longitude: 147.20515 (147° 12' 18" E)
Latitude: -43.01530 (43° 00' 55" S)
NAC:W80CK 7SWP3
