[postgis-users] query multipolygon
Paragon Corporation
lr at pcorp.us
Tue Jun 9 11:43:08 PDT 2009
Jared,
For PostGIS even though you are running on a 64-bit you have to compile in
32-bit because PostgreSQL runs in 32-bit space.
It could be the version number is off. Did you try doing a dependency walk
to see what it thinks is missing?
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of jericks
Sent: Tuesday, June 09, 2009 12:08 PM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] query multipolygon
Thanks everyone for the help so far. We checked out 3.0 from the SVN
branch, recompiled, and it solved our problem (on our development PostGIS
server).
Our production PostGIS server is 64bit and is running PostGIS 1.3.6 and GEOS
3.1.0. So, we checked out 3.1 from SVN branch, recompiled, and replacing
the DLLs didn't work. Presumably because of a 32/64 bit issue? How do you
recompile GEOS as 64bit? We are using Windows and we have access to visual
studio 2008. Is just recompiling GEOS enough?
Thanks again,
Jared Erickson
Paul Ramsey-3 wrote:
> Aha, you're exercising a bug in GEOS
> http://trac.osgeo.org/geos/ticket/244 that has been fixed but not yet
> released. If you can compile source code, compiling the 3.0 branch
> will give you the fix.
> P
> On Tue, Jun 2, 2009 at 4:07 PM, sgrocho2 <sgrocho at gmail.com> wrote:
>> I did not do the st_isvalid check on the ST_Buffer, however when I
>> removed it, the query ran fast (468ms) and gave the correct answer.
>> We use the buffer of -1 in order to minimize error in data creation
>> when trying to snap things up between layers. For example Zoning is
>> generally derived from the parcels but at times get out of alignment
>> when parcels are adjusted. The
>> -1
>> buffer takes care of the slight amount of movement created by the
>> adjustment. In this case with the fish & wildlife data the buffer
>> really serves no purpose, we can do without it since it is not parcel
derived.
>> Any
>> ideas on how to best deal with ST_Buffer?
>> Paragon Corporation-2 wrote:
>>> Did you do an ST_IsValid check on the multipolygons or the ST_Buffer.
>>> Could
>>> be the ST_buffer that is the problem.
>>> sgrocho2
>>> Sent: Tuesday, June 02, 2009 5:08 PM
>>> Okay, I did run ST_IsValid() and everything from each of the layers
>>> returned a t. When visually checking the query results with 167
>>> rows it appears that the query is only returning rows that intersect
>>> the first polygon it processes. Leaving out those rows that only
>>> intersect the other 5 polygons.
>>> The following image is an example of what is being missed. The
>>> polygons outlined in blue are not selected by the query since they
>>> only touch one of the parcel polygons(green).
>>> http://www.nabble.com/file/p23840915/missed_features.jpg
>>> Paul Ramsey-4 wrote:
>>>> Slow-vs-fast I can understand... the spatial index can more
>>>> effectively parcel out the problem for processing when the units of
>>>> processing are smaller.
>>>> Wrong-vs-right I have a problem with. Are your multi-polygons valid?
>>>> Run ST_IsValid() on them. It's possible that they are valid taken
>>>> separately but invalid when combined (multipolygons are not allowed
>>>> to have overlapping components).
>>>> Paul
>>>> On Tue, Jun 2, 2009 at 11:05 AM, sgrocho2 <sgrocho at gmail.com> wrote:
>>>>> I am having trouble querying a multipolygon feature intersection
>>>>> with another multipolygon feature. When I execute the query it
>>>>> takes 45 seconds and returns and incomplete answer, 167 rows. If
>>>>> I explode the parcel polygon into its 6 parts and then run the
>>>>> same query it takes 5 seconds and returns
>>>>> 209 rows which is the correct answer. Is there a way to write
>>>>> this query to return the all the rows without having to first
>>>>> manipulate the data? The same query works fine in SQL Server but
>>>>> we want to use PostGIS. Below is the code for each of the Parcel
>>>>> tables they include only one parcel - one with 1 row, the other with 6
rows.
>>>>> THIS IS THE SINGLE FEATURE MULTIPOLYGON CODE: 45sec 167 rows
>>>>> SELECT DISTINCT g1.objectid As taxpar_id, g1.tax_parcel_num As
>>>>> parcel_number, g2.objectid As fw_id, g2.wdfw_phs,
>>>>> g2.wdfw_occur_pt, g2.wdfw_haulout, g2.pc_for_fish,
>>>>> g2.wdfw_fish_dist, g2.pc_oaks, g2.pc_salmon, g2.wdfw_occur_pl,
>>>>> g2.doh_sf, g2.wdfw_owl, g2.pc_eelgrass, g2.pc_hydro, g2.wdfw_sasi
>>>>> FROM loader.single_parcel As g1,
>>>>> loader.potential_fw_habitat_cons_areas_pg
>>>>> As g2
>>>>> WHERE (g1.tax_parcel_num = '0618161001' AND
>>>>> ST_Intersects(ST_Buffer(g1.Shape,-1), g2.Shape))
>>>>> THIS IS THE EXPLODED 6 FEATURES CODE: 5sec 209 rows SELECT
>>>>> FROM loader.multi_parcel As g1,
>>>>> As g2
>>>>> View this message in context:
>>>>> http://www.nabble.com/query-multipolygon-tp23836573p23836573.html
>>>>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> http://www.nabble.com/query-multipolygon-tp23836573p23840915.html
>> http://www.nabble.com/query-multipolygon-tp23836573p23842660.html
http://www.nabble.com/query-multipolygon-tp23836573p23944920.html
