[postgis-users] Empty Geometry
Bob Pawley
rjpawley at shaw.ca
Tue Jun 9 13:27:18 PDT 2009
In the past, when the update conditions are not met, the update transaction doesn.t finalize.
However when I run the following update function where ST_GeometryType(temp_arrow.ithe_geom) = 'ST_MultiLineString' is not true, then the return is a null value.
Is there a workaround to this problem??
update temp_arrow
set ip_target =
( select (st_translate(graphics.utilities_dgm.the_geom,
st_x (st_startpoint(temp_arrow.ithe_geom))-
st_x (st_startpoint(graphics.utilities_dgm.the_geom)) ,
st_y (st_centroid(temp_arrow.ithe_geom))-
st_y (st_startpoint(graphics.utilities_dgm.the_geom))))
from graphics.utilities_dgm, temp_arrow, p_id.p_id, p_id.processes
where temp_arrow.graphic_id = p_id.p_id.process_graphic_id
and p_id.p_id.process_id = p_id.processes.process_id
and p_id.processes.fluid_id = temp_arrow.fluid_id
and ST_GeometryType(temp_arrow.ithe_geom) = 'ST_MultiLineString'
and graphics.utilities_dgm.utilities_description = 'Arrow_Flow_Direction'
and graphics.utilities_dgm.orientation = p_id.p_id.ip_orient );
Bob
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090609/06dfd97c/attachment.html>
