[postgis-users] query multipolygon
jericks
JERICKS at co.pierce.wa.us
Wed Jun 10 09:29:37 PDT 2009
Thank you for the information Regina. Installing the Microsoft Visual C++
2008 Redistributable Package (x86) at
http://www.microsoft.com/downloads/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&displaylang=en
solved our problem. I tried to build GEOS 3.1 branch from source using
MinGW and Msys, but it didn't work.
Jared
Paragon Corporation-2 wrote:
> Jared,
> When GEOS is distributed with PostgreSQL/PostGIS via stack builder, it is
> compiled with MingW which doesn't introduce any MSVC dependencies. I
> suppose you could copy those dlls over to the server and put them in the
> same folder with the GEOS dlls and that may work fine. I just use VS for
> ASP.Net development so all that stuff is pretty foreign to me too.
> I haven't actually tried running PostGIS with a MSVC compiled geos and at
> the moment I'm having issues compiling GEOS 3.1 branch and trunk under my
> MingW install. Could be just my MingW install, though I seem to be able
> to
> compile the GEOS 3.1 released version.
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> jericks
> Sent: Tuesday, June 09, 2009 6:14 PM
> To: postgis-users at postgis.refractions.net
> Subject: RE: [postgis-users] query multipolygon
> When I look at geos.dll or geos_c.dll with dependency walker they both
> depend on MSVCP90.dll (file not found) MSVCR90.dll (file not found)
> |_Kernel 32.dll
> Kernel 32.dll
> |_ntdll.dll
> I checked our server and it doesn't have either of these missing dlls.
> Did
> I compile with the wrong version of visual studio? I used VS 2008. I am
> a
> Java programmer, so please forgive my ignorance about dlls. Jars I know a
> lot about.
> Jared
>> Jared,
>> For PostGIS even though you are running on a 64-bit you have to
>> compile in 32-bit because PostgreSQL runs in 32-bit space.
>> It could be the version number is off. Did you try doing a dependency
>> walk to see what it thinks is missing?
>> Hope that helps,
>> Regina
>> jericks
>> Sent: Tuesday, June 09, 2009 12:08 PM
>> Subject: Re: [postgis-users] query multipolygon
>> Thanks everyone for the help so far. We checked out 3.0 from the SVN
>> branch, recompiled, and it solved our problem (on our development
>> PostGIS server).
>> Our production PostGIS server is 64bit and is running PostGIS 1.3.6
>> and GEOS 3.1.0. So, we checked out 3.1 from SVN branch, recompiled,
>> and replacing the DLLs didn't work. Presumably because of a 32/64 bit
>> issue? How do you recompile GEOS as 64bit? We are using Windows and
>> we have access to visual studio 2008. Is just recompiling GEOS
>> enough?
>> Thanks again,
>> Jared Erickson
> http://www.nabble.com/query-multipolygon-tp23836573p23952277.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
View this message in context: http://www.nabble.com/query-multipolygon-tp23836573p23966062.html
