[postgis-users] Centroid out a list of points
Pedro Doria Meunier pdoria at netmadeira.com
Fri Jun 12 02:54:11 PDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Thank you Strk.
The actual query is as thus:
select astext(st_centroid(st_collect(coordinates))) from units where
customer_id=someid
So there's a 'where' clause in it :]
EXPLAIN ANALYZE tells me:
"Aggregate  (cost=49790.11..49790.13 rows=1 width=25) (actual
time=524.380..524.381 rows=1 loops=1)"
"  ->  Seq Scan on units  (cost=0.00..49790.09 rows=9 width=25)
(actual time=445.782..524.231 rows=4 loops=1)"
"        Filter: (customer_id = 20)"
"Total runtime: 524.451 ms"
The runtime is a bit stiff, don't you agree? ;-)
BR,
Pedro Doria Meunier
GSM: +351 96 17 20 188
Skype: pdoriam
strk wrote:
> On Fri, Jun 12, 2009 at 10:34:21AM +0100, Pedro Doria Meunier
> wrote:
>> -----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
>> Thank you Nicklas for your advice! That actually accomplishes it
>> with a notable exception:
>> Altough the table has a gist index on the geom column the query
>> is always executed in Seq Scan mode...
>> I ask the gurus which fx is causing this, st_centroid or
>> st_collect ?
> It's the WHERE clause driving access strategy. If you're giving no
> conditions of course sequential scan is faster. Only reason to use
> the gist geometry index is if you use the && operator in the WHERE
> clause, and the analizer finds it to be enough selective to prefere
> index vs. sequential scan.
> --strk;
> Free GIS & Flash consultant/developer      ()  ASCII Ribbon
> Campaign http://foo.keybit.net/~strk/services.html  /\  Keep it
> simple! _______________________________________________
> postgis-users mailing list postgis-users at postgis.refractions.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
Comment: Using GnuPG with Fedora - http://enigmail.mozdev.org
iD8DBQFKMiW62FH5GXCfxAsRAoCeAJ9hzJ3AUN5WnpdrDJ2Vt4BSmuS7vACgs9I2
Z3Spv30GloYiJvlDyL+4caI=
=PLXK
-----END PGP SIGNATURE-----
