[postgis-users] Centroid out a list of points
Pedro Doria Meunier pdoria at netmadeira.com
Fri Jun 12 03:20:11 PDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Strk, you're so on the money! :)
Thank you very much! The query now runs in ~40ms :P
I also wish to thank everyone gracious enough to have shared their
thoughts.
BR,
Pedro Doria Meunier
GSM: +351 96 17 20 188
Skype: pdoriam
strk wrote:
> On Fri, Jun 12, 2009 at 10:54:11AM +0100, Pedro Doria Meunier
> wrote:
>> -----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
>> Thank you Strk.
>> The actual query is as thus:
>> select astext(st_centroid(st_collect(coordinates))) from units
>> where customer_id=someid
>> So there's a 'where' clause in it :]
> The 'where' clause specifies a condition on the 'customer_id'
> field. The only index the planner might use would be on on that
> column. Have an index there (looks like the analizer already thinks
> it'd be worth using, estimating only 9 rows selectivity for that
> clause, where 4 are returned in reality)
> --strk;
>> EXPLAIN ANALYZE tells me:
>> "Aggregate  (cost=49790.11..49790.13 rows=1 width=25) (actual
>> time=524.380..524.381 rows=1 loops=1)" "  ->  Seq Scan on units
>> (cost=0.00..49790.09 rows=9 width=25) (actual
>> time=445.782..524.231 rows=4 loops=1)" "        Filter:
>> (customer_id = 20)" "Total runtime: 524.451 ms"
>> The runtime is a bit stiff, don't you agree? ;-)
> Probably. How many rows does the table have ?
> --strk;
> Free GIS & Flash consultant/developer      ()  ASCII Ribbon
> Campaign http://foo.keybit.net/~strk/services.html  /\  Keep it
> simple! _______________________________________________
> postgis-users mailing list postgis-users at postgis.refractions.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
Comment: Using GnuPG with Fedora - http://enigmail.mozdev.org
iD8DBQFKMivR2FH5GXCfxAsRAtjiAKCdjtMYlFsbeYQAISiTlp8wa7ueUACguQPb
1KTz2rJOKR4xOnxaEvjj/Ro=
=9QOL
-----END PGP SIGNATURE-----
