[postgis-users] Open buffers or parallel lines
strk strk at keybit.net
Tue Jun 16 06:14:58 PDT 2009
On Tue, Jun 16, 2009 at 01:52:33PM +0200, Andreas Neumann wrote:
> Hi all,
> I am looking for either a "parallel line" feature or "open buffers around
> a linestring element".
> The idea is to visualize a waste-water system where in large map scales
> the actual diameter of the waste-water pipes (canalization). The linecaps
> shouldn't be stroked, but the parallel offset to the centerline should be
> drawn.
> Are there any tricks how this can be done in Postgis? I see that there is
> st_buffer, but there is no option to get an open buffer or parallel lines.
See if what's currently referred to "Single-Sided-Buffer" and probably
to become "Offset Curve" is what you're looking for.
http://trac.osgeo.org/geos/ticket/215
--strk;
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
