[postgis-users] build a polygon from points
Caspa
caspa.andre at gmail.com
Tue Jun 23 00:06:46 PDT 2009
Hi, thanks for that,
those are colunm in the table :
coord1 | coord2 | coord3 | coord4 | pol
geom_data | geom_data | geom_data | geom_data | I WANT THIS
I tried with this but didnt work;
SELECT ST_MakePoly(ST_MakeLine(coord1, coord2, coord3, coord4, coord5,
coord1 ) from table
the problem is that I can't make i line from more than two points ( i'm
using postgis v 1.3.5 and geometry *ST_MakeLine*(geometry[] point_array);
doesn't work)
I'm trying to figure out how to use
geometry *ST_MakeLine*(geometry set pointfield);
but how do I build a geometry set pointfield???
sorry...really beginner!!
2009/6/22 Paragon Corporation <lr at pcorp.us>
> Andrea,
> Are those individual records or columns in the table?
> Take a look at ST_MakeLine, ST_MakePolygon, ST_BuildArea
> http://postgis.refractions.net/documentation/manual-svn/ST_MakeLine.html
> http://postgis.refractions.net/documentation/manual-svn/ST_BuildArea.html
> http://postgis.refractions.net/documentation/manual-svn/ST_MakePolygon.html
> You build a line from points with ST_MakeLine and then do a ST_BuildArea or
> ST_MakePolygon depending on your desired effect.
> Leo
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Caspa
> Sent: Monday, June 22, 2009 10:15 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] build a polygon from points
> Hi everybody,
> I'm new to postgis...
> how can i build a polygon starting from points and not from x,y coord?
> i have a table built like this:
> point1 | point2 | point3 | point4 | polygon
> guess i have to use MakeLine and MakePolygon but i can't fugure out why...
> thanks in advance
> Andrea
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090623/2cca73d7/attachment.html>
