[postgis-users] Shortest path around polygons
Suhr, Ralf
Ralf.Suhr at itc-halle.de
Thu Jun 25 07:06:34 PDT 2009
Solving your problem is not realy hard but time expensive.
- install pgRouting
- create one table for the polygons
- create one table for holding linestrings
- write a function that:
- build all possible lines in one polygon (makeline from cross join points from polygon)
- remove lines wich are outside the polygon
- write lines with extra attribute polygon_id in the linestring table
- run add_vertices (pgRouting function)
- create temporary table for your "two points" (linestring geometry)
- rerun the function for creating linstrings with the two points and all polygon points
- finaly run shortest_path( join two tables )
-----Ursprüngliche Nachricht-----
Von: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von tommy408
Gesendet: Donnerstag, 25. Juni 2009 15:35
An: postgis-users at postgis.refractions.net
Betreff: [postgis-users] Shortest path around polygons
I'm really new to PostGIS. I need to solve this problem. Find the shortest path around polygons from point A to point B.
Here is a better description: http://alienryderflex.com/shortest_path/
How can I do it with PostGIS. Or if you can give me some hints to narrow my search.
Thank you.
View this message in context: http://www.nabble.com/Shortest-path-around-polygons-tp24203378p24203378.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
