[postgis-users] Define spatial reference system for local datum
tommy408
tommytomorow at msn.com
Tue Jun 30 12:00:29 PDT 2009
I'm not mapping anything on earth. The world I'm doing is flat. The
polygons I'm drawing over is raster image I made. So I'm trying not to use
any ellipsoid projection.
Suhr, Ralf wrote:
> Do not use a local system. For everything larger than 200meters you need a
> srs definition, because you can't messure it exactly.
> Take a projection from your living area und shift your geometrys to the
> right place.
> -----Ursprüngliche Nachricht-----
> Von: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von
> tommy408
> Gesendet: Dienstag, 30. Juni 2009 12:26
> An: postgis-users at postgis.refractions.net
> Betreff: [postgis-users] Define spatial reference system for local datum
> I don't need special projection. My map is a flat plane so I'm trying to
> use local datum as my srs because a bunch of gis map design tool ask for
> it.
> So I'm trying to add a new srs into postgis spatial_ref_sys table with the
> following srstext
> LOCAL_CS["Non-Earth (Meter)",LOCAL_DATUM["Local Datum",0],UNIT["Meter",
> 1],AXIS["X",EAST],AXIS["Y",NORTH]]
> What do I put for proj4text?
> http://www.nabble.com/Define-spatial-reference-system-for-local-datum-tp24269524p24269524.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list postgis-users at postgis.refractions.net
View this message in context: http://www.nabble.com/Define-spatial-reference-system-for-local-datum-tp24269524p24277673.html
