[postgis-users] How determining a path from two points (X, Y) no nodes of the graph
Pablo Velazco Villares
pvela at uci.cu
Fri Mar 6 09:29:01 PST 2009
Hello colleagues,
I am starting my work with pgRouting not work well with road networks.
I need to know if possible or is there some function that supports the analysis of route from fucking X, Y located on or near a given edge.
ie not necessarily take into account two nodes (start or end of an edge)
requires that the resulting path includes only a portion of the edge source or target of the solution ...
thank you all and hope to have been sufficiently explicit ... because I am trying to communicate a complex issue in a strange language
if someone can give me a hand with this, it will be very grateful
determining a path from two points (X, Y) vertices of the graph no space
Paul Makensen
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090306/9a739e49/attachment.bin>
