[postgis-users] pb OpenLayers using a local Mapserver
Barend Kobben
kobben at itc.nl
Mon Mar 9 03:28:45 PDT 2009
OK, but did you try to get it working by just typing the URL in a browser?
That tests the actual Mapserver request, to see if that part of the setup
works...
Something like:
http://localhost/cgi-bin/mapserv?map=/projet2009/ICPE.map&SERVICE=WMS&VERSIO
N=1.1.1&REQUEST=GetCapabilities should result in a GetCapabilities XML being
sent to you.
Barend
On 09-03-09 08:41, "Quentin Page" <Quentin.Page at ensg.eu> wrote:
> thanks for your reponce
> but i have the same probleme the data doesnt viewed.
> quentin page
> ecole des sciences géographique
> france
>> did you try this 'just'on mapserver, ie. without OpenLayers...? To me the
>> URL to mapserver just seems to be wrong , I suspect that i.s.o.
>> 'http://localhost/cgi-bin/mapserv?/projet2009/ICPE.map',
>> it should read
>> 'http://localhost/cgi-bin/mapserv?map=/projet2009/ICPE.map',
>> Barend Köbben
>> International Institute for Geo-information Sciences and Earth
>> Observation (ITC)
>> PO Box 6, 7500AA Enschede (The Netherlands)
>> ph: +31-(0)534874253
>> _____
>> Van: postgis-users-bounces at postgis.refractions.net namens Quentin Page
>> Verzonden: zo 8-3-2009 21:14
>> Aan: postgis-users at postgis.refractions.net
>> Onderwerp: [postgis-users] pb OpenLayers using a local Mapserver
>> Hi,
>> i have got a problem using openlayers with a mapserver.
>> It seems that my use of the constructor doesnt work for any reason.
>> The mapfile which should be viewed has already worked (in PHP).
>> Could we help me please ? Is it the good way to create a openlayers ? :/
>> var map = new OpenLayers.Map('map');
>> var wms = new OpenLayers.Layer.WMS( "ICPE",
>> {layers: 'roads'},
>> {singleTile: true, opacity: 0.5, isBaseLayer : true}
>> map.addLayer(wms);
>> Thanks a lots !!!!!
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> International Institute for Geo-Information Science and Earth Observation
>> (ITC)
>> Chamber of Commerce: 410 27 560
>> E-mail disclaimer
>> The information in this e-mail, including any attachments, is intended for
>> the addressee only. If you are not the intended recipient, you are hereby
>> notified that any disclosure, copying, distribution or action in relation
>> to the content of this information is strictly prohibited. If you have
>> received this e-mail by mistake, please delete the message and any
>> attachment and inform the sender by return e-mail. ITC accepts no
>> liability for any error or omission in the message content or for damage
>> of any kind that may arise as a result of e-mail transmission.
International Institute for Geo-Information Science and Earth Observation (ITC)
E-mail disclaimer
The information in this e-mail, including any attachments, is intended for the addressee only. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or action in relation to the content of this information is strictly prohibited. If you have received this e-mail by mistake, please delete the message and any attachment and inform the sender by return e-mail. ITC accepts no liability for any error or omission in the message content or for damage of any kind that may arise as a result of e-mail transmission.
