[postgis-users] Help with query
mark balman
mark.balman at gmail.com
Tue Mar 10 06:37:59 PDT 2009
Hi Regina
Many thanks to your prompt answer, the query works great now! In my query
the coordinates were in Plate Carree metres and I think I confused myself
with the transform function. Much appreciated, any news on the proposed
postgis book?
Cheers
Mark
On Tue, Mar 10, 2009 at 12:16 PM, Obe, Regina <robe.dnd at cityofboston.gov>wrote:
> Mark,
> I'm a bit confused, for your second query, are those points suppose to
> represent user input and in long lat? They don't look like long lat. If
> they are meant to be long lat, then your args are just backwards.
> The basic idea I think you want to do is
> 1) Take user input which I presume is in 4326 and then transform it to
> Plate Carree to match your existing data?
> Note ST_GeomFromText doesn't transform anything it simply states this data
> is in long lat and then transform changes the coordinates to Plate Carree
> So should be
> ST_Intersects(pas_nat_iv_pnt.the_geom ,ST_Transform(ST_GeomFromText(userinput,4326),
> 32662) )
> Hope that helps,
> Regina
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *mark balman
> *Sent:* Tuesday, March 10, 2009 7:04 AM
> *To:* postgis-users at postgis.refractions.net
> *Subject:* [postgis-users] Help with query
> Hi all
> I am trying to create a query that returns the features intersected by a
> user defined area. I can do this with the following query which works fine
> and returns what I want:
> select areaname, country
> FROM pas_nat_iv_pnt
> where ST_Intersects(pas_nat_iv_pnt.the_geom ,
> ST_GeomFromText('POLYGON((-7726647.392661 408830.119563 ,
> -6918290.736304 408830.119563 , -6918290.736304 828801.112346 ,
> -7726647.392661 828801.112346 , -7726647.392661 408830.119563 ))' , 32662)
> However, what I need to do is to have a user enter latitude and longitude
> values and then transform these into Plate Carree coordinates, I have tried
> the following query:
> FROM pas_nat_iv_pnt
> transform(ST_GeomFromText('POLYGON((-7726647.392661 408830.119563 ,
> 32662),4326))
> The query runs but returns no rows.. I would be most grateful if anyone
> could enlighten me on what is wrong and what I need to change.
> TIA
> Mark
> *The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant to
> Massachusetts law. It is intended solely for the addressee. If you received
> this in error, please contact the sender and delete the material from any
> computer. *
> *Help make the earth a greener place. If at all possible resist printing
> this email and join us in saving paper. *
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090310/9ba51f48/attachment.html>
