[postgis-users] Can I build an index on combinednon-spatial&spatial columns?
Paragon Corporation
lr at pcorp.us
Wed Mar 18 05:31:28 PDT 2009
M.A.,
My gut feeling tells me having 2 partial indexes on the same field as you
have described is just bad. How would the planner know which to choose
unless you always have the filter in there. If you only have 2 sets of data
then breaking it out is even more silly. If you later add more building
types, then you would never do an indexed searches on those.
You'd be better off having a single gist index on the geometry and possibly
a btree index on the building_type. Though if you only have 2 building
types, that index would never need to be used. PostgreSQL is quite
efficient at using bit map indexes. To my knowledge you can't really
combine a gist and btree type in a single compound index and you wouldn't
want to anyway.
The child table approach is generally the preferred way of doing this, but
even that is not necessary if you have less than a million records or if you
wan that benefit of quickly reloading all buildings or all schools (by being
able to do a TRUNCATE TABLE).
Regardig your query, your query as it stands will not use any indexes. You
should write it using the ST_Dwithin function which does use indexes.
SELECT the_geom, building_name
FROM buildings
WHERE building_type = 'School' AND ST_DWithin(the_geom, 'POINT(100312
102312)', 5000)
Leo
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of M.A.
(Thijs) van den Berg
Sent: Wednesday, March 18, 2009 8:08 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Can I build an index on
Thanks, that's true. I think the performance benefit with be good because I
have approx 10.000 building_type's (although, that's a lot of indices to
choose between). A typical distance query for a specific building_type will
result in 10-100 matches. Not using partial indexing will thus result in
appox 500.000 rows for each query (all building types), which I would then
have to filter on building_type, reducing the resultset with a factor 10.000
Giving it some more thought, I think splitting the building table into
individual building_type tables (and attaching spatial indices to
those) might be the best solution.
From a technical point, I think the postgresql CREATE INDEX should support
multiple USING to allow for mixed patial / non-spatial indices, something
like this:
CREATE INDEX blabla ON buildings (USING HASH(building_type), USING
GIST(the_geom))
internally that could be rewritten as
CREATE INDEX blabla_hash_value1 ON buildings USING GIST(the_geom) WHERE
hash(building_type)=value1 CREATE INDEX blabla_hash_value2 ON buildings
USING GIST(the_geom) WHERE hash(building_type)=value2 ..
On Mar 18, 2009, at 12:43 PM, Kemal Bayram wrote:
> Well according to EXPLAIN a partial index is taken into account, how
> much of a performance benefit you gain ultimately depends on how many
> records lie within your average distance.
> If your data set is relatively static you may also want to consider
> clustering your table too.
>> M.A. (Thijs) van den Berg
>> Sent: 18 March 2009 13:00
>> Subject: Re: [postgis-users] Can I build an index on combined
>> Thanks :)
>> Does PostGIS support partial indices?
>> http://www.postgresql.org/docs/8.3/interactive/indexes-partial.html
>> If so.. I could do something like this:
>> CREATE INDEX building_type_spindx_school ON buildings USING
>> GIST(the_geom) WHERE building_type='School';
>> CREATE INDEX building_type_spindx_bar ON buildings USING
>> GIST(the_geom) WHERE building_type='Bar';
>> Yet another option would be to partition the buildings table into
>> child tables per building_type (ie have child table containing all
>> the schools, another child table having all the bars), and have
>> individua spatial indices on the child tables. Is that an option?
>> On Mar 18, 2009, at 11:36 AM, Kemal Bayram wrote:
>>> I don't know about combining indexes but you want to
>> include a spatial
>>> operator such as && in addition to Distance so that you can take
>>> advantage of an index on "the_geom".
>> Behalf Of
>>>> Sent: 18 March 2009 11:57
>>>> To: postgis-users at postgis.refractions.net
>>>> Subject: [postgis-users] Can I build an index on combined
>> non-spatial
>>>> &spatial columns?
>>>> Suppose I want to speedup the following type of queries with an
>>>> index:
>>>> FROM buildings
>>>> WHERE Distance(the_geom, 'POINT(100312 102312)') < 5000 AND
>>>> Is that possible, and if not, why not? My current option
>> is to write
>>>> my own index storage in C++, using a hashmap to filter
>> building_type,
>>>> and build separate spatial indices for each building type.
>> Can I do
>>>> something similar in postgresql?
>>>> Would my only option be to split the building_types into separate
>>>> tables?
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
