[postgis-users] Feautures omitted from ST_Buffer operation
Roger André randre at gmail.com
Thu Mar 26 10:48:56 PDT 2009
Ok, here is the WKB.  Let me know if there are any problems with the file.
On Thu, Mar 26, 2009 at 8:57 AM, Martin Davis <mbdavis at refractions.net>wrote:
> I don't think this can be the problem - a buffer of a linestring should
> still produce a polygon.
> This is probably a bug in the GEOS buffer algorithm.  It would help if you
> posted the WKB or WKB for the geometry.
> Chris Hermansen wrote:
>> This sounds to me like you might be buffering a linestring and not a
>> polygon.  Is that possible?  Ie are the countries represented as
>> outlines (linestrings) rather than polygons?
>> Roger André wrote:
>>> Hi All,
>>> I'm having some problems with features that are being returned from an
>>> ST_Buffer operation in PostGIS.  When I try to buffer the extents of
>>> Papua New Guinea, a large region in the middle of its extents is
>>> omitted.  You can see a visual representation of this at
>>> http://lagerratrobe.blogspot.com/2009/03/problem-with-postgis-stbuffer.html
>>> If I just select the country itself, I get back all of the features
>>> that I'm expecting.  In the image I've posted above, the black area
>>> indicates the results of that query.
>>> I am using postgresql-8.3.5, and postgis-1.3.3.  My select statements
>>> is as follows:
>>>    select name, Buffer(the_geom, .12) from coastlines where
>>> iso_3_code = 'PNG';
>>> I've tried this using both a free countries shapefile, as well as an
>>> ESRI one, and get the same results.  I'm a bit baffled, and unsure if
>>> I have a problem with both data sets, or in my query, or...?  If
>>> someone else has had a similar problem in the past, and can shed some
>>> light on it, I'd greatly appreciate it.
>>> Thanks in advance,
>>> Roger
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090326/e073f8d4/attachment.html>
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
