[postgis-users] Postgis and Ramdisk
Andreas Neumann
a.neumann at carto.net
Fri May 1 03:01:21 PDT 2009
answering my own email with a new question on the same topic:
Increasing the shared_buffer value, does this have the same effect as
storing all data in a ramdisk?
Here is a little discussion on the topic:
http://magazine.redhat.com/2007/12/12/tip-from-an-rhce-memory-storage-on-postgresql/
Here is one quote from the discussion:
"Increasing shared buffers can effectively keep a db in memory. The
default configuration has traditionally been way too conservative - am
sure someone will eventually get round to writing a script to tune
configuration based on a user response to questions and hardware probing.
Course if the data is not critical and you just need something
lightweight there are application specific options…"
Any other online-resources on the topic?
Thanks,
Andreas
Andreas Neumann wrote:
> Hi,
> I wonder if people have experiences with running Postgis with
> tablespaces on a ramdisk?
> How are the performance gains - is it worth a try?
> My DB is several hundred mb (300-400 - may grow), the physical RAM is
> 8GB. Most of the DB is read-only. I would perhaps only store the
> read-only part in the RAM-disk and the read-write part on harddisk.
> Thanks for any hints, resources or experiences regarding Postgis and
> RAM-Disk.
> Andreas
> postgis-users mailing list
