[postgis-users] Correct use of ST_Transform
benton101
Ben.Davies at dec.wa.gov.au
Mon May 4 23:34:56 PDT 2009
> Why do you have 3 columns in the select writing into two in the INSERT?
> Shouldn't it be:
> INSERT INTO spl_road_centre_line(
> gid, the_geom
>SELECT gid, st_transform(the_geom, 4283)
> FROM spl_road_centre_line_mga
> ORDER BY gid ASC;
Simon,
You are correct, I have in error included 3 columns, but even so when I have
run the query with the correct number of columns, I dont seem to have
records that are transformed.
So the query that I have constructed would be the way to transform records
from one coord system to another?
Ben
View this message in context: http://www.nabble.com/Correct-use-of-ST_Transform-tp23380852p23381799.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
