[postgis-users] Creating polygons from lines fails
Stefan Donath
DonathStefan at gmx.de
Tue May 5 04:05:28 PDT 2009
Hi Kevin,
thanks for mailing!
I do the following command:
INSERT INTO pl_zonen_gen VALUES ('SELECT right_pl_zone,
ST_BuildArea(ST_Collect(geometry))
FROM pl_zonen_kante_gen GROUP BY right_pl_zone','xxxx')
I get error message:
ERROR: parse error - invalid geometry
SQL Status:XX000
What does that refer to?
To make my problem more clear: I have a table with edges of german
postal code areas and attributes like right_pl_zone=<postalcodearea1>
and left_pl_zone=<postalcodearea2> and I need to create polygons from that.
I have an empty polygontable with a geometry field and a character field
for the postalcode
I want to do something like this (with vb.net):
for each postalcode in postalcode_list
INSERT INTO polygontable VALUES(MakePolygon(SELECT geometry FROM
geomtable WHERE right_pl_zone=postalcode OR left_pl_zone=postalcode),
postalcode)
next
So maybe you would like to help me again with the SQL-string or give me
an advice how to do it! Thanks a lot!
Stefan.
Kevin Neufeld wrote:
> Use ST_Polygonize() or ST_BuildArea() depending on your preference.
> ie.
> SELECT attribute1, attribute2, ST_BuildArea(ST_Collect(my_line_geom))
> FROM my_line_table
> GROUP BY attribute1, attribute2;
> -- Kevin
> Stefan Donath wrote:
>> Hi
>> I need to create polygons from lines. Using OpenJUMP it works fine
>> with the geometry but I'm loosing all attribute data!
>> Could anyone please tell me how to do that in PostGIS!
>> Thanks a lot - Stefan.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
