[postgis-users] Re: errors loading postgis.sql
rahul.pachaghare at tcs.com rahul.pachaghare at tcs.com
Wed May 13 03:42:53 PDT 2009
Yes ...I tried doing with that also....but still the same error.....
[Rahul at localhost postgis-1.3.6]$ psql -d psqldb -f lwpostgis.sql | less
psql:lwpostgis.sql:44: NOTICE:  type "histogram2d" is not yet defined
DETAIL:  Creating a shell type definition.
psql:lwpostgis.sql:44: ERROR:  could not load library
"/usr/local/pgsql/lib/liblwgeom.so": libgeos_c.so.1: cannot open shared
object file: No such file or directory
psql:lwpostgis.sql:50: ERROR:  current transaction is aborted, commands
ignored until end of transaction block
psql:lwpostgis.sql:56: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:62: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:70: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:88: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:94: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:100: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:106: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:113: ERROR:  current transaction is aborted, commands
Regards,
Rahul Pachaghare
Member,TEG Open Source
Tata Consultancy Services
Mailto: rahul.pachaghare at tcs.com
Website: http://www.tcs.com
____________________________________________
Experience certainty.   IT Services
                  Business Solutions
                  Outsourcing
             strk
             <strk at keybit.net>
             Sent by:                                                   To
             postgis-users-bou         PostGIS Users Discussion
             nces at postgis.refr         <postgis-users at postgis.refractions.
             actions.net               net>
        cc
             05/13/2009 01:37                                      Subject
             PM                        [postgis-users] Re: errors loading
                                       postgis.sql
             Please respond to
               PostGIS Users
                Discussion
             stgis.refractions
                   .net>
On Wed, May 13, 2009 at 12:52:41PM +0530, rahul.pachaghare at tcs.com wrote:
> Hi..
> Thank you for your reply....
> the first few lines are:
>  psql -d newpsqldb -f lwpostgis.sql -U postgres | less
Did you run 'ldconfig' as root after installing GEOS ?
--strk;
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
ForwardSourceID:NT00003AB2
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
