[postgis-users] How to improve performance of ST_Within in a small table with large geometries
Jorge Arévalo jorge.arevalo at gmail.com
Wed May 13 07:37:21 PDT 2009
Hello,
As I said in these threads:
http://postgis.refractions.net/pipermail/postgis-users/2009-May/023369.html
http://postgis.refractions.net/pipermail/postgis-users/2009-May/023415.html
We're working with a table of large geometries (multipolygons) and small
number of rows. We want to check in which multipolygon of this table are the
points of another table. This another table has ~8 million of points. The
SQL code is:
--loop for all polygons. T1 has polygons, but we use the center, a point, to
do the Within
for i in select ogc_fid from T1 LOOP
    update T1
    set field_to_update = (select updating_field  from T2 where
ST_Within(ST_Centroid(T1.wkb_geometry), the_geom) LIMIT 1 OFFSET 0)
    where ogc_fid = i;
END LOOP
--end of loop
(We have to update one table with a field of the another one, but the
important part is the ST_Within part)
In the worst case (point is in the last multipolygon) the query takes 1sec.
In the best case, takes 16msec. If we take into account the worst case only
(this is, all the queries will take 1sec), we're talking about 93 days... We
need to improve the performance of this.  So, we tried:
- Force using index instead of sequential scan (SET enable_seqscan TO off).
It didn't improve the speed
- Use bounding box of multipolygons instead the multipolygons (ST_Envelope).
We can't do this because bounding box doesn't take into account
InnerBoundaries inside multipolygons, and we have multipolygons with "holes"
filled of other multipolygons
- Clustering of indexes. It didn't increase the speed
- Force_2D(). It didn't increase the speed significantly
We're using PostGIS 1.3.5 with GEOS and PROJ support, over PostgreSQL 8.1.1.
Our operating system is Suse Linux Enterprise. The hardware is an Intel XEON
2.5 GHZ (64 bits) and 4GB RAM.
How could we improve the performance of this? 93 days are too much time. Is
it possible to take advantage of the 4-core processor, for example?
Thanks in advance
Best regards
Jorge
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090513/9dc61be9/attachment.html>
