[postgis-users] Postgis upgrade
Mateusz Naskręt -GEOPOZ-
mateusz.naskret at geopoz.poznan.pl
Thu May 21 03:51:09 PDT 2009
Hi everyone,
I have done and upgrade of Postgres (from 8.2.3 to 8.3.5) and Postgis
(from 1.2.1 to 1.3.5). Everything on SLES 11.
I do not know enything about spatial data - i am only server
administrator :)
In general upgrade is finished and everybody are working on it for few
days - and i do not have an information about problems.
But in log from upgrade ("Hard upgrade" from online documentation) i can
see few errors. Can anyone look to it and tell me if there can be
problems in feature ? Or maybe i can forget about it and eveyting will
be fine ?
ERROR: language "plpgsql" allready exist
CREATE FUNCTION asgml(geometry, integer, integer) RETURNS text
AS '$libdir/liblwgeom.so.1.2', 'LWGEOM_asGML'
LANGUAGE c IMMUTABLE STRICT;
ERROR: could not access file "$libdir/liblwgeom.so.1.2": No such
file or directory
ALTER FUNCTION public.asgml(geometry, integer, integer) OWNER TO
postgres;
ERROR: function public.asgml(geometry, integer, integer) doesn't exist
And similar for functions:
public.asukml(geometry, integer, integer)
public.asukml(geometry, integer)
public.asukml(geometry)
public.st_pointn(geometry)
ERROR: cast from type pg_catalog.bool to type text allready exist
I have translated errors from polish so there can be a diffence to
english errors - but the meaning should be fine.
For me fist error is not important but what about rest ?
When i was looking to upgrade log file in every SQL like: "CREATE
FUNCTION" there is "AS '/usr/lib/liblwgeom', " instead of "AS
'$libdir/liblwgeom.so.1.2'". Maybe some bug in upgrade script ?
Do you think it is good idea to copy SQLs creating this functions above
from .ascii file (temporary file created by upgrade script), replace
$libdir/liblwgeom.so.1.2 with /usr/lib/liblwgeom and run SQL ?
I haven't done "cleaning" described in "Hard upgrade" in postgis
documentation. Is is important ? Are missing functions important ?
Thanks for any info or hint,
Mateusz Naskręt
