[postgis-users] ST_NumPoints
Ben Madin ben at remoteinformation.com.au
Mon May 25 06:55:06 PDT 2009
G'day,
This may be way off your problem, and in fact may not matter at all,
but I am led to believe that :
On 21/05/2009, at 4:39 PM, Kis János Tamás wrote:
> I have a big table (with 21000 rows):
> CREATE TABLE kecskemet_k.foldreszletek
> ( sorszam bigserial NOT NULL,
>  hrsz text,
>  geometria geometry --POLYGON
> ) WITH (OIDS=TRUE);
> CREATE INDEX i_foldreszletek_geometria ON kecskemet_k.foldreszletek
> USING gist (geometria);
1. it is better practice to add the geometry column to the table after
generating the table using the postgis addGeometryColumn() function.
2. you may be better to add a gid column than using OIDS
So your table creation might end up looking like :
( gid serial unique,
  hrsz text
SELECT
AddGeometryColumn
('kecskemet_k','foldreszletek','geometria',-1,'POLYGON',2);
I hope this is correct and not unhelpful.
cheers
Ben
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
							Out here, it pays to know...
