[postgis-users] Coordinate changes using transform from 1.3.1 to 1.3.6
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Tue May 26 04:39:52 PDT 2009
Miguel R. Luaces wrote:
> Dear all,
> we have a PostgreSQL 8.1 database with postgis 1.2 installed. We have
> some data in the database stored using EPSG:23029.
> We make a backup with pg_dump and we restore the database in PostgreSQL
> 8.2 with Postgis 1.3.1 without any problem.
> But, if we restore the backup in PostgreSQL 8.2 with Postgis 1.3.6, the
> function transform() returns a different result. More precisely:
> The same query:
> select astext(the_geom), astext(transform(the_geom)) from monumentos
> where id = ,
> In Postgis 1.3.1:
> "Castelo de San Antón";"POINT(549556.009066526
> 4801796.3531214)";"POINT(-8.38839299999999 43.3657910268222)"
> In Postgis 1.3.6:
> 4801796.3531214)";"POINT(-8.38839299999999 43.3666118995462)"
> The second coordinate of the transformation to 4326 changes by 0.004
> degrees (approx).
> Any idea?
> Thank you very much in advance.
> Best regards,
>   Miguel
Hi Miguel,
What versions of PostgreSQL/PostGIS are you using on both servers, and
with which versions of the PROJ.4 library?
SELECT version(), postgis_full_version();
Also can you confirm that the spatial_ref_sys entries for 23029 and 4326
are identical between the two servers?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
