[postgis-users] Coordinate changes using transform from 1.3.1 to 1.3.6
Ben Madin ben at remoteinformation.com.au
Tue May 26 05:58:39 PDT 2009
G'day Miguel,
On 26/05/2009, at 8:23 PM, Miguel R. Luaces wrote:
> First DBMS:
> SELECT version(), postgis_full_version();
> "PostgreSQL 8.2.13 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC)
> 3.4.2 (mingw-special)";"POSTGIS="1.3.1" GEOS="3.0.0rc4-CAPI-1.3.3"
> PROJ="Rel. 4.5.0, 22 Oct 2006" USE_STATS DBPROC="0.3.0"
> RELPROC="1.3.1" (needs proc upgrade)"
> Second DBMS:
> 3.4.2 (mingw-special)";"POSTGIS="1.3.6" GEOS="3.1.0-CAPI-1.5.0"
> PROJ="Rel. 4.6.1, 21 August 2008" USE_STATS DBPROC="0.3.0"
> RELPROC="1.3.6" (needs proc upgrade)"
I'm sure you can see the difference between postgis and especially
proj versions from this. I would guess you will need to either upgrade
one machine or downgrade the other to be able to expect absolute
concurrence.
cheers
Ben
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
							Out here, it pays to know...
