[postgis-users] ESRI GDB format into PostGIS
Piotr Synowiec psynowiec at gmail.com
Thu May 28 12:41:59 PDT 2009
Frank Warmerdam wrote:
> Are you suggesting that Manifold GIS has reverse engineered the file
> geodatabase format?  Can you provide any pointers supporting that?
> If those guys can reverse engineer it, then so could we given enough
> desire.
I'm using Manifold on daily basis. Not to import ESRI files.
Just looked through all possible imports and couldn't find ESRI GDB file
Piotr
