[postgis-users] ESRI GDB format into PostGIS
Simon Greener
simon at spatialdbadvisor.com
Thu May 28 16:39:23 PDT 2009
Mike,
> I had to check the current version. Manifold, like OGR, only supports ESRI Personal Geodatabase (*.mdb) format. Not ESRI File Geodatabase format. See: http://www.manifold.net/info/formats.shtml
Personal and Enterprise (SDE) GeoDatabases and NOT File GeoDatabases the situation with 8.0.x. (It may change in the up and coming 9.0 beta.)
regards
Simon
> -Mike
> ----- Original Message -----
> From: "Frank Warmerdam" <warmerdam at pobox.com>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Thursday, 28 May, 2009 10:23:02 GMT -08:00 US/Canada Pacific
> Subject: Re: [postgis-users] ESRI GDB format into PostGIS
> Simon Greener wrote:
>> Paul et al,
>>> Bended knee. You've been supplied with a "file base geodatabase" and the
>>> only things that will open it are ESRI products or things licensing ESRI
>>> products.
>> Or products that have been provided with enough instance examples to be able
>> to reverse engineer. Manifold GIS is one such product. I don't have any GDB
>> examples to check its ability to suck the data out.
> Simon,
> Are you suggesting that Manifold GIS has reverse engineered the file
> geodatabase format? Can you provide any pointers supporting that?
> If those guys can reverse engineer it, then so could we given enough
> desire.
>>> http://blog.cleverelephant.ca/2009/04/esri-formats-back-to-future.html
>> Something I totally agree with. There was a brief discussion on "The
>> Shapfile 2.0 Manifesto"
>> (http://moreati.org.uk/blog/2009/03/01/shapefile-20-manifesto/) about what
>> should replace the shapefile. The ESRI file based GeoDatatabase was
>> discussion with Scott Morehouse himself telling everyone about a non
>> ArcObjects based API that would open up interoperability etc (the usual
>> smoke and mirrors). No talk about the format specs being donated to the
>> public domain; nothing about how the API would be licensed. You will never
>> see an FDO Provider from ESRI I would guess. More of the same "do it our
>> way or the highway"....
> I too am disappointed that ESRI declared they would provide open access
> to file geodatabases, and then let the actually follow through drag on
> for years after they came into initial use. However, I do believe they
> are contemplating a reasonably open API - possibly source included. They
> have also been considering support for an FDO and/or OGR provider. I'm
> a bit vague on the current plan but they are aware of these possibilities
> and are interested in doing them. So don't be so sure about what will
> never happen.
> Best regards,
SpatialDB Advice and Design, Solutions Architecture and Programming,
Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME, Radius Topology and Studio Specialist.
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
Website: www.spatialdbadvisor.com
Email: simon at spatialdbadvisor.com
Voice: +61 362 396397
Mobile: +61 418 396391
Skype: sggreener
Longitude: 147.20515 (147° 12' 18" E)
Latitude: -43.01530 (43° 00' 55" S)
NAC:W80CK 7SWP3
