[postgis-users] ST_Union does not exist
Dylan Beaudette
debeaudette at ucdavis.edu
Thu May 28 17:41:51 PDT 2009
On Thursday 28 May 2009, Paragon Corporation wrote:
> Dylan,
> Did it work before? Aggegates unfortunately don't get upgraded since there
> is no CREATE OR REPLACE AGGREGATE logic in PostgreSQL, so if you have been
> upgrading the same db prior to 1.3 -- unless you manually run those CREATE
> AGGREGATE calls, they won't be there.
Ah, ok. I didn't realize this. I was able to make things work by loading
lwpostgis.sql-- after removing the transaction checks. Not sure if this was
the proper thing to do... I had been upgrading this DB since postgis-1.2, so
those AGGREGATE statements had never been run.
This would be a nice bit of advice in the Installation section of the manual--
i.e. something about when just running lwpostgis_upgrade.sql is not enough.
Thanks for the advice!
Dylan
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Dylan
> Beaudette
> Sent: Thursday, May 28, 2009 3:13 PM
> To: PostGIS Users Discussion
> Subject: [postgis-users] ST_Union does not exist
> Hi,
> Noticed this today:
> -- basic query
> SELECT ST_Buffer(ST_UNION(wkb_geometry), 0.1) as wkb_geometry FROM
> SELECT 1 as id, wkb_geometry
> FROM map
> ) as a
> GROUP BY a.id;
> -- error message
> ERROR: function st_union(geometry) does not exist
> -- software version (Postgresql 8.3.7)
> POSTGIS="1.3.6" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007"
> USE_STATS
> Could this be related to my recent upgrade from postgis 1.3.3 ? Other
> postgis queries seem to work.
> I was able to get a result using GeomUnion(geometry)--- but for anything
> more than a couple features this would take > 1 hour, not finishing, and
> could not be canceled by the user.
> Grepping through the source reveals:
> /src/postgresql-8.3.7/contrib/postgis-1.3.6$ grep -R -i
> 'st_union(geometry)' *
> postgis_comments.sql:COMMENT ON AGGREGATE ST_Union(geometry) IS 'args:
> g1field - Returns a geometry that represents the point set union of the
> Geometries.';
> Ideas?
> Dylan
> Dylan Beaudette
> Soil Resource Laboratory
> http://casoilresource.lawr.ucdavis.edu/
> University of California at Davis
> 530.754.7341
> postgis-users mailing list
Dylan Beaudette
530.754.7341
