[postgis-users] AddGeometryCOlumn error on View
Piotr Synowiec psynowiec at gmail.com
Fri May 29 02:42:08 PDT 2009
Hi
I have view created from 2 tables to select and combine data I need.
I tried to add geometry column with below command but it failed.
SELECT AddGeometryColumn( 'my_view', 'geom_field', -1, 'GEOMETRY',2);
Instead I used
INSERT INTO geometry_columns
(f_table_catalog,f_table_schema,f_table_name,f_geometry_column,coord_dimension,srid,type)
VALUES ('','public','my_view','geom_field',2,-1,'GEOMETRY')
and it worked, why shouldn't.
I can use this view as geometry drawing in Manifold.
I can't use it in QGIS, as QGIS complains that view doesn't have a
unique ID column.
Is there any particular reason why AddGeoemtryColumn doesn't work on Views ?
Another question is how to create unique ID for a View ?
Regards
Piotr
