[postgis-users] Unable to build WKT Raster
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Mon Nov 2 07:12:20 PST 2009
There is no technical reason that should prevent WKT Raster of working with any recent version of PostGIS. The doc should not then be changed. If it does not compile it is another story.
If Kevin's trick does the job we can document it.
Pierre
>-----Original Message-----
>From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>bounces at postgis.refractions.net] On Behalf Of Mark Cave-Ayland
>Sent: 2 novembre 2009 08:45
>To: PostGIS Users Discussion
>Subject: Re: [postgis-users] Unable to build WKT Raster
>Gilles Bassière wrote:
>> I also tried to build and install PostGIS 1.4.0 but I can't find a way
>> to do so within my home directory since the --prefix option is now
>> ignored (bug #160). Of course, I could compile a full PostgreSQL in my
>> home directory but there might be an easier solution, is there?
>PGXS makes use of the DESTDIR variable for installation, so for a
>relocated install all you need to do is:
>./configure
>make DESTDIR=/path/to/output install
>HTH,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>Sirius Labs: http://www.siriusit.co.uk/labs
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
