[postgis-users] Unable to build WKT Raster
Gilles Bassière
gilles.bassiere at makina-corpus.com
Mon Nov 2 15:08:11 PST 2009
Mark Cave-Ayland wrote:
> PGXS makes use of the DESTDIR variable for installation, so for a
> relocated install all you need to do is:
> ./configure
> make DESTDIR=/path/to/output install
Thanks a lot, that information I was missing. PostGIS build just fine now.
When loading PostGIS however I got error because Postgres was not able
to find $libdir/postgis-1.4. Is it caused by forcing custom installation
path at install level?
Since I'm simply setting this up to try out wkt raster, I went for the
quick and dirty way: replacing $libdir by the absolute path to
postgis-1.4.so.
Regards
Gilles Bassière - MAKINA CORPUS
http://www.makina-corpus.com
