[postgis-users] SOLVED: Combining / agglomerating / clustering numbers of adjacent polygons
nicklas.aven at jordogskog.no
Thu Nov 5 04:49:12 PST 2009
I don't know if I have misunderstood this, but to me it looks like what you are doing is:
create table agglom_areas as
select (st_dump(st_union(the_geom))).geom as split_geom
from grid_squares;
with cascaded union (geos 3.1 or higher) this should befast as I understand it.
But if I have missunderstood everything, just ignore it :-)
/Nicklas
2009-11-05 Derek Jones wrote:
Dear Leo
>Hey thanks!
>Since these and other steps can run for several tens of minutes or even
>hours because of the data densities, I didn't notice because I left them
>each cooking and did something else instead, but I appreciate any
>improvements here because I may well be running the same kind of query
>elsewhere also.
>Occam's Razor and all that ;-)
>Kind regards
>Derek.
>Paragon Corporation wrote:
>> Derek,
>> FWIW -- this is a bit faster and shorter to write than your last step. You
>> probably won't notice the difference until you start dealing with huge
>> geometry collections.
>> --REVISED LAST STEP
>> create table
>> agglom_areas
>> as
>> SELECT (ST_Dump(the_geom)).geom As split_geom
>> FROM temp_f;
>> ---YOUR LAST STEP--
>> create table
>> agglom_areas
>> as
>> select
>> st_GeometryN
>> the_geom,
>> generate_series(1,st_NumGeometries(the_geom))
>> ) as split_geom
>> from
>> temp_f;
>> Leo
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Derek
>> Jones
>> Sent: Wednesday, November 04, 2009 10:26 PM
>> Cc: PostGIS Users Discussion
>> Subject: [postgis-users] SOLVED: Combining / agglomerating / clustering
>> Dear all,
>> I solved the problem with just a handful of lines of SQL in the end... :-P
>> Kinda roundabout thinking but it worked. Here's the solution:
>> grid_squares contains my reduced grid set from the complete grid overlay
>> from a previous select - it's the density table. I also previously removed
>> singletons from it with a check for any grid entries that had 0 touching
>> entities.
>> # Break out the multipolygon grids into polygons
>> create table
>> temp_e
>> as
>> select
>> st_GeometryN
>> the_geom,
>> ) as split_geom
>> from
>> grid_squares;
>> # Break out the polygons into linestrings and agglomerate into areas #
>> Becomes one big area as a multipolygon so ...
>> create table
>> temp_f
>> as
>> select
>> st_buildarea
>> st_collect
>> st_ExteriorRing(split_geom)
>> ) as the_geom
>> from
>> temp_e;
>> # ... afterwards, break out into polygons again # each of which is the
>> clustered set of # polygons comprising the outer boundary agglomeration # of
>> the original grid areas.
>> create table
>> agglom_areas
>> as
>> select
>> st_GeometryN
>> the_geom,
>> ) as split_geom
>> from
>> temp_f;
>> I can probably with a little work reduce the steps but I don't have a need
>> to at this point.
>> This does exactly what I wanted - hope it's useful perhaps to others in the
>> same jam. Appreciate the help given in any event.
>> Now I can use the generated areas to get me some centroids and then both
>> intersect and then cluster the "other" data set I have which is 10s of 1000s
>> of points and different to this one but related to it.
>> Thank you again. Always useful to bounce these kinds of things around...
>> Kind regards
>> Derek Jones
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091105/209037ea/attachment.html>
