[postgis-users] Using plpgsql for in select with st_dump
Kevin Neufeld
kneufeld at refractions.net
Fri Nov 6 20:22:10 PST 2009
You have a typo in both of your "output := ..." lines. You've declared
tmpgeo, not tempgeo.
Also, you're missing a line to increment count. Perhaps after the inner
if statement, "count := count+1;"
Hope that helps,
Kevin
Moen, Paul T. wrote:
> I am trying to expand my horizons and learn some plpgsq. I want to
> split out a list of points from a multipoint via plpgsql into json,
> not geojson. I get the following notices.
> ERROR: missing FROM-clause entry for table "tempgeo"
> LINE 1: SELECT $1 ||'{"x":'|| $2 ||',"y":'||tempgeo.they||'}'
> QUERY: SELECT $1 ||'{"x":'|| $2 ||',"y":'||tempgeo.they||'}'
> CONTEXT: PL/pgSQL function "pointsfromgeom" line 16 at assignment
> ********** Error **********
> SQL state: 42P01
> Context: PL/pgSQL function "pointsfromgeom" line 16 at assignment
> Is there any way to do this? Does the record type have to be based on
> an existing table? Is this the right list to ask?
> CREATE OR REPLACE FUNCTION pointsfromgeom(ingeom GEOMETRY) RETURNS
> TEXT AS $$
> DECLARE
> geotype TEXT;
> output TEXT:='';
> BEGIN
> SELECT INTO geotype geometrytype(ingeom);
> IF (geotype = 'MULTIPOINT') THEN
> DECLARE
> tmpgeo RECORD;
> count integer :=1;
> BEGIN
> FOR tmpgeo IN SELECT DISTINCT st_x((st_dump(ingeom)).geom) as
> thex,st_y((st_dump(ingeom)).geom) as they
> LOOP
> IF (count=1) THEN
> output := '[{"x":'||tmpgeo.thex||',"y":'||tempgeo.they||'}';
> ELSE
> output := output||',{"x":'||tmpgeo.thex||',"y":'||tempgeo.they||'}';
> END IF;
> END LOOP;
> output:=output||']';
> END;
> ELSE
> RAISE NOTICE 'Geometry type is not compatable';
> RETURN NULL;
> END IF;
> RETURN output;
> END;
> $$ LANGUAGE 'plpgsql';
> Thanks,
> Paul
> postgis-users mailing list
