[postgis-users] Is that possible a function to behave differently inside and outside another main function code?
    Kevin Neufeld
    kneufeld at refractions.net
    Sun Nov  8 09:25:37 PST 2009
Are you sure you want to use "UNION" and not "UNION ALL"?  The former
will remove duplicates, the latter does not.  It's conceivable that when
UNIONed, the three SELECT st_X clauses will return a single value.
Collected and put through ST_LineFromMultiPoint would probably result in
a single point line (depending on which version of PostGIS you are using
- the newer versions will ERROR with "geometry requires more points").
Hope that helps,
Kevin
rodrigosperb wrote:
> Hello,
> I have a bit of a problem that is sort of driving me crazy. I need to
> perform an "addition of two (mathematical) functions". I represent them as
> linestrings in my solution, and it is part of another bigger function. The
> code is as follows:
> ...header...
> SELECT st_LineFromMultiPoint(st_Collect(st_MakePoint(xy.t,xy.at)))
> FROM (SELECT q.t, dr_delay_value($1,q.t) +
> dr_delay_value($3,dr_delay_value($1,q.t)) AS at
>       FROM (SELECT st_X(st_PointN($1,n)) AS t
> 	    FROM generate_series(1,st_NumPoints($1)) AS h(n)
> 	    UNION
> 	    SELECT st_X(st_PointN($2,n)) AS t
> 	    FROM generate_series(1,st_NumPoints($2)) AS h(n)
> 	    UNION
> 	    SELECT st_Xmax($1) AS t
>             ) AS q ORDER BY q.t) AS xy
> ...bottom...
> dr_delay_value() is simply a look-up function that takes the Y value for a
> certain X.
> The thing is that eventually this fuction is failing on returning more
> specifically a 2-points linestring (that sould) and returns only a single
> point one. Now, I have prepared a "wrapper" PL/Pgsql function to keep track
> of what is passed to that function (perhaps that was the reason for the
> error. With that I'm pretty much sure that the arguments passed are fine,
> and still get the same error... Strangely, with my wrapper function keeping
> track of the arguments passed to the function I was able to try out to run
> the same request (that inside of the bigger function fails) separately, and
> guess what? is simply works!!
> I hope anyone may have a clue of what is going on. That's a very strange
> behavior, I would say.
> Regards,
> Rodrigo Sperb
