[postgis-users] st_buffer?
Raffaele Morelli raffaele.morelli at gmail.com
Wed Nov 11 05:24:57 PST 2009
2009/11/11 Nicolas Ribot <nicolas.ribot at gmail.com>
> > Hi you all,
> > I am new to the list so apoligize for any repetitiveness.
> > I am working to build a "corridor" around a multiline postgis layer,
> let's
> > say 50mt left and 50mt right lines.
> > How can I accomplish this task? I did it in the past using st_buffer but
> I
> > didn't work with postgis since 2007 and now I am completely stucked on
> that.
> Hi,
> it should work
> What's the error message, the postgis version (select
> postgis_full_version() ) ?
> Nicolas
Yes, it works... apologize, the geometry_columns table can still be a
nightmare when working with views after a couple of years
Anyway, I did it with GRASS too, using v.parallel and then using shp2pgsql,
so now I can use both ;-)
Thanks for reply
Regards
-r
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091111/7da95969/attachment.html>
