[postgis-users] Postgis concurrence question
Mateusz Loskot mateusz at loskot.net
Wed Nov 11 09:52:47 PST 2009
Nandorov wrote:
> Hello list,
> I need some advices of what i'm trying to do. I have a lot of GPS devices
> that are sending data(every 10 seconds) to an application (Java). The latter
> connects to a Postgis database and inserts the coordinates as POINT datatype
> in a table. For testing, i'm using the super user postgres
> Everything's working fine after 20 or 15 minutes, the application starts to
> throw the following postgis error:
> "could not connect to server: connection timed out (0x0000274C/10060)
> Is the server running on host "127.0.0.1" and accepting TCP/IP connections
> on port 5432"
> Some statatements can be executed and some other can not
> It could be a problem for using the super user postgres or something related
> to max_connections (Currently set at 100) in postgres.conf?
Read the logs, Luke!
Check PostgreSQL manual about logging options, enable
detailed logging, check if you get anything interesting.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
