[postgis-users] Can I replace all the x and y coordinates of a geometry using PostGIS, Thank you!
Paragon Corporation
lr at pcorp.us
Wed Nov 11 10:39:20 PST 2009
Not sure what you are trying to do, but one of the affine functions like
ST_Translate may be what you are looking for.
http://www.postgis.org/documentation/manual-1.5SVN/ST_Translate.html
That will move all the points in the geometry a specified amount in x,y,z
Leo
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
ZHANGAIGUO
Sent: Wednesday, November 11, 2009 11:50 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Can I replace all the x and y coordinates of a
Hello Postgis-users:
I am a student in Fuzhou University, China.
In using PostGIS,
I encountered a problem as fellows:
How can I replace all the x and y coordinates of a geometry?
The geometry may be point, multipoint, linestring, multilinestring, and so
on.
I have tried to use the way as fellows:
CREATE OR REPLACE FUNCTION aigo_coord_offset_basicframe2(geometry, double
precision, double precision)
RETURNS geometry AS
$BODY$
declare i integer;
compress geometry;
geom1 geometry;
begin
i:=1;
geom1:=ST_GeomFromText('LINESTRING(0 0, 0.0001 0.0001)',21460);
while i<= ST_NumPoints($1) loop
geom1:=ST_AddPoint(geom1,ST_MakePoint(int2(ST_X(ST_PointN($1,i))-$2),int2(ST
_Y(ST_PointN($1,i))-$3)));
i:=i+1;
end loop;
geom1:=ST_RemovePoint(geom1,0);
compress:=geom1;
return compress;
end $BODY$
LANGUAGE 'plpgsql' VOLATILE
COST 100;
ALTER FUNCTION aigo_coord_offset_basicframe2(geometry, double precision,
double precision) OWNER TO post;
The way above is just applied to LINESTRING geometry type,
and it is inefficient.
Are there any other solutions to accomplish it?
Thank you!
Sincerely Yours!
ZHANG Aiguo
_____
Messe nger保护盾2.0,更安全可靠的Messenger聊天! 现在就下载!
<http://im.live.cn/safe/>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091111/93cef440/attachment.html>
