[postgis-users] Is that possible a function to behave differently inside and outside another main function code?
Rodrigo Sperb rodrigosperb at gmail.com
Wed Nov 11 20:01:59 PST 2009
Hello,
Following what Kevin said about UNION ALL, I have tried to change the code
(below) using UNION ALL and then SELECT DISTINCT (as I need the same X may
be in both functions and I don't want a replicate. But I still ge the same
error (eventual single-point Linestring that should never happen. Here is
the code (so that I don't need to look-up the previous message:
 ...header...
  SELECT st_LineFromMultiPoint(st_Collect(st_MakePoint(xy.t,xy.at)))
>   FROM (SELECT q.t, dr_delay_value($1,q.t) +
> dr_delay_value($3,dr_delay_value($1,q.t)) AS at
--- dr_delay_value is a simple look-up function for a certain X value....
>        FROM (SELECT st_X(st_PointN($1,n)) AS t
>            FROM generate_series(1,st_NumPoints($1)) AS h(n)
>            UNION
>            SELECT st_X(st_PointN($2,n)) AS t
>            FROM generate_series(1,st_NumPoints($2)) AS h(n)
>            UNION
>            SELECT st_Xmax($1) AS t
>              ) AS q ORDER BY q.t) AS xy
>   ...bottom...
I then changed it to:
>   FROM (SELECT DISTINCT q.t, dr_delay_value($1,q.t) +
>            UNION ALL
>            UNION
>   ...bottom...
And I know what went inside when I got the error was:
Inputs of function:
$1 = LINESTRING(28800 28809.0366506299,28826.9908145614 28836.029580065)
$2 = LINESTRING(28800 45.4281818181818,28826.9908145614 45.4299607582325)
$3 = LINESTRING(0 43.53,52800 47.01,62700 74.87,86400 43.53) - edge delay
function
Output:
result =
LINESTRING(28800 28854.4654280455) - thus is missing a pair
X=28826.9908145614, Y = 28836.029580065 + Y of $3 for 28836.029580065
But here is what I find most intriguing: if I simulate the inputs above
outside of the main function (in which this one that is returning an
eventual error runs), it simply works.
SELECT
st_AsText(dr_sum_arrivaltime_edgedelay(st_GeometryFromText('LINESTRING(28800
28809.0366506299,28826.9908145614 28836.029580065)'),
45.4281818181818,28826.9908145614 45.4299607582325)'),
                                    st_GeometryFromText('LINESTRING(0
43.53,52800 47.01,62700 74.87,86400 43.53)')))
= "LINESTRING(28800 28854.4654280455,28826.9908145614 28881.46013656)"
I hope anyone can give me a clue on that one. It's sort of really bothering
already, as I can't imagine why that happens...
Best regards,
Rodrigo Sperb
> Message: 7
> Date: Sun, 08 Nov 2009 09:25:37 -0800
> From: Kevin Neufeld <kneufeld at refractions.net>
> Subject: Re: [postgis-users] Is that possible a function to behave
> To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> Message-ID: <4AF6FF11.3080607 at refractions.net>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Are you sure you want to use "UNION" and not "UNION ALL"?  The former
> will remove duplicates, the latter does not.  It's conceivable that when
> UNIONed, the three SELECT st_X clauses will return a single value.
> Collected and put through ST_LineFromMultiPoint would probably result in
> a single point line (depending on which version of PostGIS you are using
> - the newer versions will ERROR with "geometry requires more points").
> Hope that helps,
> Kevin
> rodrigosperb wrote:
> > Hello,
> > I have a bit of a problem that is sort of driving me crazy. I need to
> > perform an "addition of two (mathematical) functions". I represent them
> as
> > linestrings in my solution, and it is part of another bigger function.
> The
> > code is as follows:
> > ...header...
> >           UNION
> >           UNION
> > ...bottom...
> > dr_delay_value() is simply a look-up function that takes the Y value for
> a
> > certain X.
> > The thing is that eventually this fuction is failing on returning more
> > specifically a 2-points linestring (that sould) and returns only a single
> > point one. Now, I have prepared a "wrapper" PL/Pgsql function to keep
> track
> > of what is passed to that function (perhaps that was the reason for the
> > error. With that I'm pretty much sure that the arguments passed are fine,
> > and still get the same error... Strangely, with my wrapper function
> keeping
> > track of the arguments passed to the function I was able to try out to
> run
> > the same request (that inside of the bigger function fails) separately,
> and
> > guess what? is simply works!!
> > I hope anyone may have a clue of what is going on. That's a very strange
> > behavior, I would say.
> > Regards,
> > Rodrigo Sperb
> Message: 8
> Date: Sun, 8 Nov 2009 09:26:41 -0800 (PST)
> From: rodrigosperb <rodrigosperb at gmail.com>
> To: postgis-users at postgis.refractions.net
> Message-ID: <26255804.post at talk.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> Hi Kevin,
> Thanks for your repply. I can't be sure whether the two functions have the
> same X value, and I don't want them twice, that's why I was using UNION,
> instead of UNION ALL (which is much faster even...).
> But what you said make some sense. Do you think if use first a UNION ALL
> and
> then in the outer query (when I order by q.t) I use DISTINCT may work?
> I think I will try it out.
> Thanks again for the help.
> Rodrigo Sperb
> > Hope that helps,
> > Kevin
> > rodrigosperb wrote:
> >> Hello,
> >> as
> >> The
> >> code is as follows:
> >> ...header...
> >>          UNION
> >>          UNION
> >> ...bottom...
> >> a
> >> certain X.
> single
> >> track
> fine,
> >> keeping
> >> run
> >> and
> >> Regards,
> >> Rodrigo Sperb
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> http://old.nabble.com/Is-that-possible-a-function-to-behave-differently-inside-and-outside-another-main-function-code--tp26251542p26255804.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> End of postgis-users Digest, Vol 87, Issue 9
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091112/eb2dc805/attachment.html>
