[postgis-users] Can we use PostgreSQL/PostGIS without Python?
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Tue Nov 17 06:25:56 PST 2009
kreshna_iceheart at yahoo.com wrote:
> What is the worst thing can happen when running PostgreSQL without Python?
> Many thanks,
> -Kresh
Nothing - it just means that you can't use the plpython(u) stored
procedure languages within PostgreSQL. Note that all the message means
is that you are missing the Python development packages from your system
- if you install them, then the build should proceed normally.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
