[postgis-users] Small benchmark with PostGIS and MS SQL-Server Spatial: Adjustment
rkrummen at hsr.ch
rkrummen at hsr.ch
Mon Nov 23 09:45:36 PST 2009
Two weeks ago, my advisor Stefan Keller posted some queries about database benchmarking. We would like to thank you for the useful suggestions. Wherever possible we adapted our queries. Due to restrictions in time, data and the limited spatial functionality of MS SQL Server, we could not implement any proposed refinement, but we like to show you what we got now. Feel free to comment.
- Roland
1. Loading data and generating indices
SELECT * INTO {dataset} FROM {original dataset}
WHERE ST_Intersects(@geom, the_geom) ;
ALTER TABLE {dataset} ADD PRIMARY KEY (gid);
CREATE INDEX gidx ON {dataset} USING gist (the_geom);
2. Non-spatial selection query
SELECT Count(*) FROM {dataset lines} l
WHERE l.roadflg='Y';
3. Spatial query I:
a)
SELECT Count(*) FROM {dataset points} p
WHERE ST_Intersects(@poly, p.the_geom) ;
b)
SELECT Count(*) FROM {dataset polygons} pg
WHERE ST_Intersects(@geom, pg.the_geom) ;
c)
WHERE ST_Intersects(@geom, l.the_geom) ;
4. Spatial query II:
a)
WHERE ST_DWITHIN(@point, p.the_geom, x)
b)
WHERE ST_DWITHIN(@point, pg.the_geom, x)
c)
WHERE ST_DWITHIN(@point, l.the_geom, x)
5. Join of a linestring and a polygon table
SELECT SUM(ST_Length(pg.the_geom)) FROM {dataset lines} l
JOIN {dataset polygons} pg ON ST_DWITHIN(pg.the_geom, l.the_geom, 10)
WHERE l.railflg = 'Y'
