[postgis-users] Run on database or not?
Martin Davis mbdavis at refractions.net
Tue Nov 24 08:59:34 PST 2009
Actually the JTS Java library (which PostGIS uses the C port of) is
generally quite a bit faster than the same routine inside PostGIS.  The
"maths" is not the hot spot in the geometric routines.
There are reasons why you might not want to load all data into
client-side memory (eg code complexity and data volume) but performance
is *not* one of them.
The best caching that you can do for this case is to use a
PreparedGeometry for your target "large data".  PostGIS does some of
this already, although it may or may not be able to be applied in your
queries.  If you implement this client-side in Java you can easily
construct your code so that all tests are carried out against
PreparedGeometrys.
Brian Modra wrote:
> 2009/11/24 tommy408 <tommytomorow at msn.com>:
>> I have a web application that requires a lot of queries, like 200 queries a
>> second.  And they're mostly running ST_Within on large data.  Should I just
>> load the data into memory to do the calculations ( I'm using java)  or keep
>> them in postgres and run the queries?  I don't know if database already
>> doing caching.
> ST_within is a function, as far as I know, its not doing its own caching.
> But the database does naturally cache. So if you do the same query
> again, it won't have to do so much IO... and the gist index will
> probably also be in cache.
> You'll have to benchmark it yourself, because it depends a lot on your
> data and query.
> But caching and doing the calculations in memory using Java will
> likely be slow anyway if the data is large, because Java is not great
> for maths. Rather cache one complete result with its query data, and
> then if a matching query comes in, you have the results already. But
> let the database find the result in the first place rather than do the
> maths in Java.
>> View this message in context: http://old.nabble.com/Run-on-database-or-not--tp26494921p26494921.html
>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
