[postgis-users] pgsql2shp: date field
Paul Ramsey pramsey at cleverelephant.ca
Fri Nov 27 09:10:21 PST 2009
I've placed a ticket on this with a patch
http://trac.osgeo.org/postgis/ticket/321
If you would try and patch and see if it creates files that are more
broadly usable, that would be nice.
Thanks,
Paul
On Fri, Nov 27, 2009 at 5:28 AM, Peter Hopfgartner
<peter.hopfgartner at r3-gis.com> wrote:
> Hi,
> we currently have some interoperability problems with pgsql2shp generated
> shapes. Basically, if a date field is NULL, pgsql2shp writes all zeros to
> the file. This file can not be opened with gvSIG and OpenOffice, whereas it
> can be opened with ArcGIS and MS-Excel 2003 (showing the zeros).
> If I overwrite these zeros (from the hex editor) with spaces, all of the
> above programs do open and interpret the NULL value correctly.
> I've attached a dump of the database and the generated shape file and the
> version with the zeros replaced with spaces.
> I have not found any spec how dBase III should represent NULL data values
> and forward this problem to the ML, but the files written in ArcGIS use
> spaces, too.
> Another issue: pgsql2shp writes the integer field "ID" aligned to the left,
> when written from ArcGIS it is aligned to the right.  Indeed, some tools
> seem to have problems in interpreting the value written.
> Regards,
> Peter
> Dott. Peter Hopfgartner
> R3 GIS Srl - GmbH
> Via Johann Kravogl-Str. 2
> I-39012 Meran/Merano (BZ)
> Email: peter.hopfgartner at r3-gis.com
> Tel. : +39 0473 494949
> Fax  : +39 0473 069902
> www  : http://www.r3-gis.com
> Venite a trovarci all'ASITA, dal 1 al 4 dicembre a Bari www.asita.it
> Besuchen Sie uns bei der Messe ASITA vom 1. bis 4. Dezember in Bari
> www.asita.it
> Visit us at ASITA, from 1st to 4th December in Bari www.asita.it
> postgis-users mailing list
